Prevents NTP from sending broadcast messages to a VLAN.
| vlan-name | Specifies the name of a particular VLAN. |
NTP does not send broadcast messages to a VLAN by default.
N/A.
The following command prevents NTP from sending broadcast messages to a VLAN called “Northwest”:
disable ntp vlan Northwest broadcast-server
This command was first available in ExtremeXOS 12.7.
